SIP auto answer
Introduction
SIP Auto-answer is a phone feature that allows to automatically answer a call without any action by the user, such as pressing the Accept Call button.
Not all phones support auto-answer feature.
The auto-answer function can be of two types:
Auto-answer all calls (unconditional).
Auto-answer on condition.
For us only the 2-nd type is important because it is heavily used on click-to-dial operation.
When you a click the dial button on the Odoo’s partner form the following happens:
Twilio dials to user’s SIP channel (e.g. SIP/1001).
When user answers Twilio starts to place the call to the partner.
So without the auto-answer function when user clicks the dial button his phone rings and he has to click Accept call button. So one single call requires 2 clicks!
To make it one-click-operation special phones should be used that accept auto-answer feature based on SIP header. In this case when click to dial button is pressed Odoo sets a special auto-answer SIP header (every phone has his own header defined) and user’s phone automatically accepts the first call leg.
From the point of view of the user when he clicks the partner’s dial button he immediately can hear call progress tone coming from his phone.
The auto-answer feature is set in Users menu.
Phones with auto-answer support
Zoiper
Only Zoiper paid editions supports auto-answer header. Here is its SIP header: Call-Info:<sip:>;answer-after=0.
Zoiper 5: Zoiper Options window; Automation; Enable the “Accept server-side auto answer”.
Microsip
MicroSIP will play short tone and popup.
SIP header: Call-Info: Auto Answer or Call-Info: answer-after=0 or X-AUTOANSWER: TRUE
Source - https://www.microsip.org/help
