Oduist PBX Documentation
Migrate from 3.x to 4.x version notes
Starting from 4.0 Asterisk Plus module is free to use without per user subscription payment. There are special upgrade notes.
- Update the module.
- Update the Agent.
- Configure the connection between Odoo and the Agent in PBX -> Settings -> Server.
Installation process
In general, the installation process consists of the following steps:
- Download and install Asterisk PBX (if you don't have it deployed).
- Download and install Odoo (if you don't have it deployed).
- Configure Odoo for the Oduist PBX modules.
- Download and install Asterisk Plus modules.
- Install the Agent middleware (Agent acts as a bridge between Odoo & Asterisk).
- Configure Odoo to access the Agent (PBX -> Settings -> Server).
Let's dive in...
